How to fill unmerged cells with values from previous rows?
I have an excel file that does not have any merged cells. Any cell that is left blank is supposed to take the value from the previous row. How do you do that in FME without looping through a list?
This is what I have
image.pngAnd, this is what I want (with grey-color being the items I want to automate with FME)
image.png:
Best answer by nielsgerrits
In the AttributeCreator, under Advanced, you can Enable Adjacent Feature Attributes which will let you access prior or subsequent features. You can then use conditionals to set attributes, like you would do in Excel. (If A has a value, do nothing. Else, use A from the previous row.)
nielsgerrits
Forum|alt.badge.img+54
  • August 17, 2023
  • August 17, 2023
Exactly, simply adding a screenshot:
imageSee also here: https://engage.safe.com/blog/2017/08/adjacentfeatureattributes-evangelist166/
