I have upgrade from FME 2016 to FME 2021.2.
When I am running the FME script, if I don't give source dataset in SCHEMA READER then I am facing "No Schema Dataset found" issue.
But the same script runs fine on FME 2016. I think FME 2021.2 is not accepting empty string (i.e. no dataset) as input.
Is there anything I can do to fix this issue ?
