How update a column in a table with Variable Setter- Variable Retriever ?
Hi community!
I would like update a column in my table with a variable.
For that, I put in a VariableSetter my value that I retrieve after a Tester and with a VariableRetriver I recall my variable, and I want to insert this value of this variable in all the lines of my Code_Comma column.
But it's doesn't work.
Capture d’écran 2023-03-28 154641Someone can help me please ? Thanks
Best answer by dustin
Instead of VariableSetter/Retriever, use a FeatureMerger instead. The 4 features would be fed to the Requestor port, and the single feature (where you would create your Code_Comma attribute), feed to the Supplier port. In the FeatureMerger, type '1' for Requestor and '1' for the Supplier. This will essentially force the Code_Comma attribute onto the 4 features.
nielsgerrits
Forum|alt.badge.img+54
Two things about VariableSetters and Retrievers:
  • They do not always work well combined with FeatureCaching.
  • If you are using them, you need to make sure the setter is run before the retriever.
Another way to do this is to use a FeatureMerger, where you set the requestor and the supplier values to "1" instead of a value. This will add the attribute(s) of the lower stream to the features of the upper stream.
dustin
Forum|alt.badge.img+31
  • March 28, 2023
  • March 29, 2023
thank you @nielsgerrits​ and @dustin​ !
