I am trying to use a colleague's web connection to truncate/load several SDE feature classes to AGOL using parameters for the feature classes and connection files.
  • September 30, 2022
  • 10 views
I am trying to use a colleague's web connection to truncate/load several SDE feature classes to AGOL using parameters for the feature classes and connection files. (Ultimately, I want to create a workspace for specific users to access to update any desired feature service)
Everything works fine in FME Desktop.
However, after publishing to FME Server, the web connection disappears. Once I reset the parameters the connection shows up but does not persist. How do I resolve this issue?
Exhibits:
1a - published
2a - after Reset
  • October 4, 2022
It turns out that the solution was to change the published parameters to private.
