HI all, How do I convert a date time attribute of this example "44821.76657" to DD-MM-YYY HH-MM-SS? using the Attribute manager. Loading the same data in Excel I simply specify it as Date and it gives 17-09-2022 18:23:52.
eadetutu
Participant
I was told the data  "44821.76657" is the elapsed days and time since "1 Jan 1900"
Best answer by geomancer
This one had me stumped for a while, as my results kept being one day off. But it turns out all Excel versions have a deliberate bug: 1900 is considered to be a leap year(!). Apparently this was done for better compatibility with the once famous Lotus 1-2-3.
Of course all Excel functions niftily work around this real Year 1900 Bug! For more information see here.
Also bear in mind that 1-1-1900 is day 1 (not 0).
Excel_Day_NumberPlease note: This solution gives a wrong date for all 59 days in januari and februari 1900. I hope this is not a problem ;-)
  • November 8, 2022
geomancer
Forum|alt.badge.img+47
  • November 8, 2022
eadetutu
Participant
  • Participant
  • November 14, 2022
HI all, thanks for the feed back, I was able to get it solved using a combination of both of your response.
