Convert ESRI Feature Class with single feature to geoJSON MultiPolygon
jrlalessi
I have a feature class with a single feature that I need to convert to a multipolygon type geoJson file. I'm not super familiar with geoJSON, and I'm being told this is a hard requirement. How does one create a multipolygon geoJSON file from a single feature?
  • November 29, 2023
Hi @jrlalessi​ ,
You can use Aggregator to transform a polygon (so called single feature) to a multipolygon consisting of a single part. Recommended parameter settings are:
  • Group By: <Set a unique ID attribute. OBJECTID, for example>
  • Complete Groups: When Group Changes (Advaneced)
  • Aggregation Mode: Geometry - Assemble One Level
  • Accumulation Mode: Use Attributes From One Feature
jrlalessi
  • November 30, 2023
Thank you, Takashi!
This worked perfectly. I never thought to aggregate a single feature!
