How to use an attribute list an input to create filter expression in Custom Transformer
amdubois
Hello,
Here is my situation. I have nearly 500 gdbs with exactly the same schema (each gdb contains 7 feature classes). I need to merge only two feature classes. My process also involves a loop and because I do not want to read all the gdb everytime, I have an index shapefile (one feature = one gdb extent) which I intersect with the area of interest in order to extract the names of the targeted gdbs.
Right now I have come down to creating a custom transformer which is able to select the good 2 features classes but in order for my filters to work, I need to be able to input the list of the previsouly selected gdb names in my epxression. So far this is what I manage to do.
main workbench reading all gdb feature classes and generating list of gbd names to useCustom transformer trying to extract features based on list value
I know there is something missing but I can't seem to figure out what. Basically, what I need is a way to feed the list of attributes to build the expression that will filter what I need.
Thank you for your help!
Best answer by amdubois
Well I clearly don't know how to make it dynamic but this sequence works.
solution reader schema to gdb
amdubois
  • March 2, 2022
It turns out my real problem is not actually passing the attribute list, for which finally I just need to use a feature merger at the beginning of my custom transformer.
merge attribute and features
What I really seem to struggle with is reading the data from a "Any Schema Reader". I'm having trouble understanding how I can pass the values I filtered (basically feature classes) in order to get the actual features and than clip them.
reading data from any schema reader
nielsgerrits
Forum|alt.badge.img+54
This should work, but I think you need to switch Output Ports to Single Output Port.
If this doesn't work, I would try to use other attributenames than fme_dataset and fme_feature_type_name to prevent interference with the software.
amdubois
  • March 2, 2022
I have tried also with only one output, same problem.
What attributes should I used if not fme_dataset / fme_feature_type_name ?
The reader seems really the problem. Everything is sent to the initiator section.
No matter what I tried, I always get this error:
error reader schema to gdb
amdubois
  • March 2, 2022
