I am trying to clip a point cloud using the values of a csv using the reader, but the PointCloudFilter transformer does not accept the @Value() field. I am at a loss now. Any help would be great.
You need to merge the attributes from your csv onto the point cloud before you can use them in the point cloud filter, you can use the value of 1 a the requestor and the supplier, e.g.image
Fantastic! That's done it! Thanks
