How to convert points to multiple lines considering gaps in data and spatial sequence/ order
geoman
Hi Everyone,
I need your help to solve a problem. I have many no. of points that are not in order if we look at them spatially and in many places, there is a significant gap considering its distribution. I have tried Sort and then Line builder transformer in FME but the output was generated based on the layer drawing order. Another issue is line builder does not consider the gap within point distribution and connects all points to generate a single polyline. Looking for a solution to convert points to separate lines based on their spatial sequence. The attached below screenshot could make you clear about the issue I am talking about.
Forum|alt.badge.img+35
  • October 13, 2021
Are you able to share some sample data?
geoman
  • October 13, 2021
Attached sample. Thanks.
