I am trying to reproject a wms from the Environment Agency (https://environment.data.gov.uk/spatialdata/risk-of-flooding-from-surface-water-extent-0-1-percent-annual-chance/wms) from WGS 1984 to British National Grid. I need to know the cell size so I can provide a degree of accuracy of the data and have confidence in my areas of intersect calculations with some polygons. However, when I use the Reprojector, the spacing seems completely off. If I view it in ArcGIS Pro, the cell size appears to be 2m, which seems sensible. I have tweaked the parameters in the Reprojector but this doesn't give me the correct cell size. Any ideas what I'm doing wrong?
