tanveerafzal wrote:
Oracle Database column type is CLOB. for Writer i am using insert statement using SQLExecutor. oracle database is 19C.
When using an SQLExecutor, the CLOB is actually transmitted as a string literal, which is why you're running into this Oracle limitation. Remember that the SQLExecutor simply transmits the entire SQL statement as a string to Oracle, there is very little or no parsing being done by FME.
If possible, I would look into using either a FeatureWriter or a DatabaseUpdater to insert the actual CLOB value, those should be much more intelligent in how they handle LOB datatypes.
