I have a point cloud that needs to be transformed from one projection to another, using specific 7 parameters. I've tried Reprojector and EsriReprojector but none of them allowed the usage of specific parameters. I'm new to FME so sorry in advance, t
I have a point cloud that needs to be transformed from one projection to another, using specific 7 parameters. I've tried Reprojector and EsriReprojector but none of them allowed the usage of specific parameters. I'm new to FME so sorry in advance, thanks
Best answer by jlbaker2779
See the custom projection help below. It should point you in the right direction. Following this guild will create a shared projection that can be used in the transformers.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
