Have a question about working with multiple geometries exporting from SW 5.2.3 database to a SW 5.1.2 database.
We are using FME 2017.1 to transfer facilities from one company to another going from a SW 5.2.3 database to a SW 5.1.2 database.  I can connect to the SW 5.1.2 Gas_transmission dataset from the SW 5.2.3 session. When setting up my Workspace, I have multiple geometries being exported like gt_line_loop (beg_location, end,location, route_satellite and route_aerial). Iff I have 11 records that I am exporting from SW 5.2.3, I will have 4 sets in the reader (11 per geometry). If I just run a straight tranlastion, I end up 44 gt_line_loop records being inserted into the SW 5.1.2 database. I only want 11 records to be imported/inserted. I did an AttributeCreator and created sworld_geometry{0}.sworld_name for beg_location. I set up another AttributeCreator sworld_geometry{1}.sworld_name for end_location. I crete and Aggregator and do it on ID and Merge Attributes. I run translation and it appears to work fine. I get 11 records with beg_location and end_location populated. If I do AttributeCreators on route_satellite and route_aerial, let's say sworld_geometry{2}.sworld_name and sworld_geometry{3}.sworld_name, I get an error or it does not populate the route_satellite and route_aerial. I want to set this up so all four geometries get populated for just the 11 records. Need some help on this.
Thaks,
R. Mark Smith
DOminion Energy
trentatsafe
  • September 10, 2020
Hi @robe543​
I think this may have to do with how you are reading in the SW data. On the GE Smallworld Reader there are 2 settings, one preserves the multiple geomtries, the other splits the feature into each geometry type(point, line, annotation etc.)
Try changing the following parameter -
Service: from FME to FMENOFACTORY
The FME setting splits the incoming features, while the FMENOFACTORY will preserve the original feature(so they should only have 11). Let me know if that works!
  • September 11, 2020
trentatsafe wrote:
Hi @robe543​
Hi trentatsafe, I was working on gt_casing and I decided to try setting the Service to FMENOFACTORY for the Reader. Yes, it made one Feature and I got one for one records being written to the other Smallworld DB. The only thing is, it did not bring the geometries across. I did not use FMENOFACTORY for the Writer. On the gt_casing object, you can have route, extent and Annotation. Maybe, I am doing something wrong. Any other suggetions? [cid:image001.png@01D6884F.65EAF820]
trentatsafe wrote:
Hi @robe543​
Hi trentatsafe, disregard my last reply. I found that I still had an Aggregator in the Workbench. I took it out and Geometries came across and were inserted with records.
