Cut overlapping polygons based on date
I have a polygon layer with overlapping polygons. These polygons have dates. What I would like to have is no more overlapping polygons.
Where two or more polygons overlap, I would like to preserve the youngest polygon. If the size of the overlapping polygons are different, then I would like to cut out the youngest polygon and preserve what is left from the older polygon.
danilo_fme
Forum|alt.badge.img+41
  • January 17, 2023
Hi @joost​ Please, could you share your example?
Forum|alt.badge.img+31
  • January 17, 2023
An AreaOnArea Overlayer should work here, if you build a list which includes the date, you can then sort this list in descending order and use the first list element as the date for the polygon
  • January 17, 2023
@joost​ Thanks for including some sample data. I think something along the lines of this might get you close:
imageAreaOnAreaOverlayer as mentioned above, but create a list of the dates (DATUM). Use ListSorter to sort the date list then Dissolve on the first date in the list.
Example attached (FME 2022.2)
  • February 28, 2023
Hi everyone,
I am still trying to get it working. Looks like the date field is not doing what I want it to do. Still looking for the right answer, despite the help I allready got here. I put the databases and the workbench as attachment.
What I want as a result is that there are no overlapping areas anymore and that the newwest (by date) polygon stays, and even cuts out of an underlaying bigger polygon.
  • February 28, 2023
I forgot the attachment, so here it is
  • February 28, 2023
joost wrote:
Hi everyone,
Do you have an example where the output is not as you expect? If I look at polygons with ID 18 and 221 which overlap, 221 is more recent so this shape is cut out of 18
Edit: i think the step you are missing is making sure the features that are kept have the information of the most recent polygon. I would build a bigger list with all the relevant attributes then use a listindexer after the sorter to retrieve all the information from the most recent polygon in the list
  • March 1, 2023
You are absolutely right with your edit. It's about the information. Building a bigger list I can do here, i suppose:
imageThe listindexer I will try to explore, never used it.
Thanks, for so far, and maybe I will return if I cant get it right.
  • March 1, 2023
Looks like it is working, with this set up:
