For StatisticsCalculator with FME2021.1.1.0, how to add a column in the result table for "fme_feature_type" used in Group by?
  • September 29, 2022
  • 13 views
webservicessia
It is to identify the sum of which group. Otherwise, the result is a list of values (for sum) but not possible to identified which value is for each group of features.
carmijo
Forum|alt.badge.img+11
You can add an attributeexposer to expose fme_feature_type before the stat calc
If i've provided something helpful, please upvote the comment. If i've provided a solution, please mark it as 'Best Answer'. This helps the community find solutions when your question is referenced.
If I didn't provide a solution, please let me know if I can help further. Thanks! 🙂
webservicessia
  • September 30, 2022
Thank you.
I already tried it and this provided a list of values without the "content" of the Fme_feature_type: ,imageI would like to get something like :
Potatoe : 845
Salad : 1496
instead of
vegetables :
845
1496
carmijo
webservicessia wrote:
Thank you.
Potatoe : 845
Salad : 1496
instead of
vegetables :
845
1496
add fme_feature_type in the list of statistics to calculate and find the min, just to get the text. then you can build a string with an attribute manager @value(vegetables): @value(count)
