Hi all! I have 2 polygon layers entitled TPL Corridors and Concepts and TDE Projects. I would like one project number attribute currently only existing in the TPL layer translated into the TDE Projects layer ONLY for polygons that overlap with one an
boomer87
Forum|alt.badge.img+5
The project number attribute from the TPL Corridors and Concepts layer did not exist in the target TDE Projects layer. However, I created a separate workspace that added in the field of TPL_Project_Number field into the TDE Projects layer already, so the target TDE Projects layer has the field in the table.
This is my current workspace.
imageThis is how the attribute manager configuration is:
imageThe issue I am experiencing is that the script is inserting new records with just the tpl_project_number into the target TDE Projects layer, but I want these tpl_project_numbers inputted into the target TDE Projects layer for only the TDE Projects and TPL Corridors and Concepts polygons that overlap one another into the existing corresponding records, and not new ones altogether if that makes sense.
imageIs there another transformer that would enbale me to do this or is there a transformer I am missing here?
Be the first to reply!
