I have an attribute that I want to split into component parts. What transformer will accommodate wild cards etc. or varying delimiters into its logic?
mdk
"4;30;4;20;SW,SE",,,
Here is my attribute string, I want everything between the quotes to be split at the ; and the rest to be split at the commas. (There are no values held there in this example.) Please help. m
nielsgerrits
I would use the stringreplacer with regex and replace all variants with one delimiter, then use the attributesplitter to split.
muzhnasto
Forum|alt.badge.img+12
  • June 24, 2021
Hi. Try it like this
list
geomancer
Forum|alt.badge.img+47
  • June 25, 2021
