Hello Community, I need to write objects in a versioning complex feature class, but FME gives me the following error:
An error occurred while attempting to store a row into the table 'UTARC.FCL_S_MESSPROJEKT'. The error number from ArcObjects is: '-2146233079'. The error message from ArcObjects is: {Der Erfassungsmaßstab wurde nicht initialisiert.}
I didn't understand the error since it is in other language. I have verified the workspace which is attached to this thread. Reader is polygon type and writer is line type, if this is the requirement then transform polygon feature to line feature as well
Sorry, a part of the message is in german and mean "The acquisition scale has not been initialized
When i change the writer to geodb_polygon i became the same error.
