Hi Guys, no so sure if this questions belongs here:
1st> what's the best way to have an internal (to the workbench) datasheet (4 columns x 20 raws of values). Is it in the workspace resources?
2nd: I am reading +storing a sequence of characters from a file (a file that I am uploading and processing). I want to compare this sequence (a name) with the aforementioned database in question 1 (actually with one column of the database), So when getting a coincidence name=cell A1 , I will store or been able to retrieve the values of the other cells within the same raw (cell A2, cell A3, and cell A4) .
Thank you very much!
Jorge
