Hello,
I have created a workspace that works as it is in FME 2018.0.
However now, when trying to upgrade, I seem to be getting validation errors, which I have not encountered before. After examining the outputs, they are different, as seen on the image.
gml_differences
When running the translation in FME 2018.0 every feature is treated as FeatureMember, since 2018.1 it is behaving as seen on the right side, it's one giant FeatureMember. Any help how where can I fix this in newer versions?
Thanks for any help,
Radek
Hi drejkzet,
maybe it is not of great help, but with FME 2019.2.0.0 I succeded in writing a gml dataset complian with Inspire schema GeographicalNames, and it has all the feturemembers in it, one for each feature.
Bye
