I am reading a feature class from sde and using schema mapper mapping the names of input and output attributes. Finally using a dynamic writer I'm writing it to a shapefile. I have a workspace resource which reads a file and defines the schema. In the dynamic writer schema definition, I have given schema sources as the workspace resource . The attribute names are as expected in the output shapefile. But there are no values for any of the columns. They are just empty. Not sure what the mistake is. Any help appreciated
