Zigzag remover (Python error )
  • August 24, 2023
  • 8 views
soly
Forum|alt.badge.img+3
Hello,
it is first time ,I use zigzag transformer but I got error .
python caller failed to process feature .
how could I fix it ?
i have used spike remover for the same input lines data and it works great without problem .
which transformer is better (spike or zigzag) ?
which angle that should I use from your experience ?
thanks in advance
FME 2021
danilo_fme
Forum|alt.badge.img+45
  • October 13, 2023
Hello @soly​
Please, could you share us your log file?
Thanks in Advance,
Danilo
