How to resize geodatabase image attachment using pythonCaller (Python 3.7)
bgeorges
Forum|alt.badge.img+5
I would like to use the PIL module to resize an image stored in a blob (geodatabase attachment table) but I cannot create the Image object from the string representation in the pythonCaller
This is what I have tried so far:
import fme, fmeobjects
from PIL import Image
from io import StringIO
def processFeature(feature):
  string_io = StringIO(feature.getAttribute("data"))
  img = Image.open(string_io) #here I have the following error: Python Exception <OSError>: cannot identify image file <_io.StringIO object at 0x0000000007CE4438>
  img = img.resize((1000, int(round((width / float(img.size[0])) * img.size[1]))), Image.ANTIALIAS)
I have the following error Python Exception <OSError>: cannot identify image file <_io.StringIO object at 0x0000000007CE4438>
Best answer by david_r
Why not simply use the RasterResampler transformer?
  • July 13, 2021
bgeorges
  • July 13, 2021
Thank you for your suggestion David!
I found out I needed to use the RasterReplacer first to get the raster from the blob field and finally the RasterExtractor to put it back into it.
fme_raster
