I'm reading an Excel file using the Excel Reader. The reader works well for all fields except one. It consistently marks all the values in a particular numerical column 'Number of meters' (column G of each sheet) as missing. The file is open data but a copy has been attached for convenience: https://www.gov.uk/government/statistics/lower-and-middle-super-output-areas-gas-consumption
How can I fix an issue with Excel Reader writing values in column as missing
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
