How do I write two different file formats to one zip file?
  • September 28, 2016
  • 79 views
fmelizard
Forum|alt.badge.img+17
fmelizard
If you are using traditional writers, then I believe it's as easy as specifying the same zip file name for both Writer's dataset parameter.
It definitely works this way for the FeatureWriter. Here is an example:
write-to-the-same-zip-file.fmw
fmelizard
  • September 29, 2016
Also check out https://knowledge.safe.com/articles/673/zip-your-output-with-fme.html -- you can use this technique and have multiple traditional writers where you specify the same path to a zip file and then even different directories inside that zip file where the output will be placed. For example:
Your textfile writer might have its output dataset as c:\\temp\\package.zip\\readme.txt
In the same workspace, your shape writer would have: c:\\temp\\package.zip\\roads
And your XML writer would have: c:\\temp\\package.zip\\metadata\\roads.xml
One zip file would be created, and within it, the data would live in the subidirectories specified. Cool.
tono
Forum|alt.badge.img+11
  • September 8, 2020
Missing link here. Could you please send it again? Thanks in advance!!!
LizAtSafe
Forum|alt.badge.img+15
  • September 16, 2020
Hi @tono​ I've fixed the link.
