local coordinate system
Does anyone have a workflow for projecting data to a local coordinate system with an arbitrary origin? The CommonLocalReprojectors has the origin centered on the bounding box of the features.
Best answer by david_r
if it's only the origin that needs fixing, perhaps the Offsetter could help?
David
