AreaOnAreaOverlayer - Sharp Edges
Hello there,
I have a question regarding the AreaOnAreaOverlayer. When I use that transformer to clean my polygons I get some polygons with really sharp edges. Is there a way to avoid this? I guess it is random on how it decides which polygon to cut from another polygon when they overlap, right?
Thanks very much in advance for your help!
Forum|alt.badge.img+49
Are those edges visible in the original data as well?
If so, you can try cleaning up the data by using the tolerance parameter in the AreaOnAreaOverlayer (FME 2019) or a Snapper.
drc43
Forum|alt.badge.img+11
  • June 28, 2019
A SpikeRemover or AreaGapAndOverlapCleaner transformer may also help clean that up.
