I want to create boundaries on some point cloud data (see https://knowledge.safe.com/questions/109029/how-to-create-disjoint-boundaries-of-disjoint-clus.html )
Note that the point cloud data were previously stored in an oracle dabatse as multipoint
For some reason, the ETL get stuck during the boundary polygons creation with the HullReplacer
My datasets is very big (~ 26 millions of points). I would like to know if there are some transformers like pointcloudthinner for single multipoint in order to reduce the density of the input points or if there a reverse transformer for pointcloudcoercer so that I can reconvert first the single multipoints to a pointcloud and then use for instance the PointCloudThinner before sending the data to a Hull replacer
Thanks
