upgrade transformer FMEServerJobSubmitter to version some outputs disappears
rudy_v
Hi All,
I have upgrade my FMEServerJobSubmitter to version 3 from 2, and now some output parameters has disappeared.- i have been using the number of features output, time start and time finish
version 2 below
after upgrade, it is no longer available, and make the attribute manager fail
  • April 17, 2018
Actually, the previous versions of the FMEServerJobSubmitter had a slightly broken logic, where e.g. the _numFeaturesOutput attribute would be exposed even when Wait for jobs to complete = No, which didn't make any sense.
Now, the attributes are dynamic according to how you set the "Wait for job" parameter.
Wait for jobs to complete = Yes
Based on the fact that your output port is called "Submitted" and not "Succeeded", I'm guessing Wait for jobs to complete = No in your workspace. If you change it around, you should get back the missing attributes.
rudy_v
  • April 17, 2018
@david_r - thanks for the update - but you don't get the succeeded / failed if
wait for job to complete is a published parameter
  • April 18, 2018
Ah, that's an interesting edge case, thanks for pointing that out.
It kinda makes sense, however, since parameters aren't resolved before you actually execute the workspace. But still, I can see how that's annoying in this case.
