Find text at a specific distance
Hi all,
In autocad, I have a file containing information I would like to merge.
Using the picture below will help to figure out the situation :
I have a block and texts. I want to add the text string "(1.00) Z=190.98" to a new attribute of my block.
Offsets between text insertion's point and block insertion's point are always the same offset x= 0.14 offset y = -1.25.
Then the next step is to compute the value. Ideally, the attribute must have the calculated value 191.26-1.40= 189.86.
Any ideas ?
Thanks
Arka
Best answer by stalknecht
Use the coordinates of the block and use a vertexcreator (replace with point) to create the point with the offset. Use a PointOnPointOverlayer to identify the desired point. For the last part split the text of the value and use the arithmetic calculator to get the calculated value.
stalknecht
Forum|alt.badge.img+19
  • August 30, 2018
  • September 4, 2018
Hi @stalknecht,
Thank you for your answer, it works !
Now I have a problem to write the "new value" as attribute of the block.
What is the best way to fill in an attribute info ?
stalknecht
  • September 4, 2018
arka wrote:
Hi @stalknecht,
Please check the following link and examples: https://knowledge.safe.com/articles/22968/getting-started-with-autocad.html
  • September 4, 2018
My problem is solved now (I was wrong in a transformer before the "writer").
Nevertheless, thank you
