SpatialRelator with Requestor Overlaps Supplier
I am working for finding related geometry data between Parcel and Planning Zone. Aiming is for finding multiple Planning Zone which is overlapping with Parcel. But all data are not calculated because of "INVALID_BASE_GEOMETRY_TYPE". I have not idea why is invalid geometry type. And Parcel is Polygon Type and Planning Zone is GEOMETRYCOLLECTION (POLYGON ...). Any idea what can to fix this process will be great for me. Thanks.
And I've attached FME Wokspace and below are Error log and Sample data for Parcel and Planning Zone.
- Sample Data
. Parcel
POLYGON ((143.82624186 -37.5940732299999, 143.8259628 -37.59404054, 143.82595252 -37.5940960899999, 143.82594294 -37.5941478199999, 143.826222 -37.5941805099999, 143.82624186 -37.5940732299999))
. Planning Zone
GEOMETRYCOLLECTION (POLYGON ((146.455556005 -37.143706338, 146.45550502 -37.1436816799999, 146.455434477 -37.1436527879999, 146.455345498 -37.1436179469999, 146.455263636 -37.14358784, 146.455192521 -37.143561736, 146.455083973 -37.1435227549999, 146.455001462 -37.1434933539999, 146.454901989 -37.1434578409999, 146.454829829 -37.143434525, 146.45476054 -37.1434122119999, 146.454688435 -37.1433934099999, 146.454610291 -37.143375297, 146.454540243 -37.1433565889999, 146.454487201 -37.1433475109999, 146.454421036 -37.143341526, 146.454344289 -37.1433369449999, 146.454275517 -37.143332933, 146.454160765 -37.1433434899999, 146.454094908 -37.143360125, 146.454026532 -37.1433790959999, 146.453942459 -37.1434123229999, 146.453863875 -37.1434425149999, 146.453788327 -37.1434767699999, 146.453687369 -37.143531187, 146.453645107 -37.143560206, 146.453576533 -37.1436177429999, 146.453535294 -37.1436609909999, 146.453485552 -37.1437204229999, 146.453449604 -37.1437746949999, 146.453420179 -37.143824488, 146.45339401 -37.1438742039999, 146.45337289 -37.1439196119999, 146.453353508 -37.143966387, 146.453305746 -37.1440878349999, 146.453264342 -37.1441393709999, 146.453211663 -37.144182483, 146.453151812 -37.1442167289999, 146.453099815 -37.1442299129999, 146.453037434 -37.1442272859999, 146.452988253 -37.1442103799999, 146.452988129 -37.144319244, 146.452987192 -37.145142654, 146.452987065 -37.1452539589999, 146.453160612 -37.1452637249999, 146.453284241 -37.1452578089999, 146.453394659 -37.1452417359999, 146.453447767 -37.1452302609999, 146.453543511 -37.1452014119999, 146.45358981 -37.145180986, 146.453647428 -37.145148176, 146.453701196 -37.145107954, 146.45373336 -37.1450760189999, 146.45377824 -37.145020175, 146.453808006 -37.144973901, 146.453827212 -37.1449380299999, 146.453846759 -37.1448928789999, 146.453869551 -37.144821334, 146.453890286 -37.1447538359999, 146.453962721 -37.1445055249999, 146.454007249 -37.1443433279999, 146.45402871 -37.144265553, 146.454050303 -37.1442059, 146.454071346 -37.1441571519999, 146.454092455 -37.14411444, 146.454123002 -37.1440633039999, 146.454153395 -37.1440199109999, 146.454188914 -37.1439751079999, 146.454220836 -37.1439390259999, 146.454260678 -37.14389865, 146.45432494 -37.143845509, 146.454400565 -37.1437990819999, 146.454449944 -37.1437757919999, 146.454524612 -37.1437488299999, 146.454582373 -37.1437339459999, 146.454640662 -37.1437236699999, 146.454718146 -37.1437173539999, 146.454758648 -37.143715739, 146.454867647 -37.1437162409999, 146.45499319 -37.143725837, 146.455096975 -37.143741996, 146.455234112 -37.143768396, 146.455338601 -37.1437901479999, 146.455438261 -37.1438108799999, 146.455480908 -37.143820714, 146.455518407 -37.143821615, 146.455556654 -37.143810344, 146.455581096 -37.1437935989999, 146.455602029 -37.143761979, 146.455589577 -37.143725242, 146.455556005 -37.143706338)))
- Errors
The below feature caused the translation to be terminated
Storing feature(s) to FME feature store file `C:\\GIT\\GLIS2\\GLIS.ETL\\GLISRAW.FME\\LOAD_DATA_GOVERNMENTLANDPLANNINGZONE_New_log.ffs'
Feature Type: `FEATURE_TYPE'
Attribute(encoded: UTF-8) : `ADDRESS' has value `37 FAIRHOLME BOULEVARD BERWICK 3806'
Attribute(64 bit integer) : `GLID' has value `117328'
Attribute(encoded: UTF-8) : `PARCELSPI' has value `A\\PS439634'
Attribute(string) : `fme_feature_type' has value `RAW_GOVT_LAND_GEOM'
Attribute(string) : `fme_geometry' has value `fme_aggregate'
Attribute(string) : `fme_rejection_code' has value `INVALID_BASE_GEOMETRY_TYPE'
Attribute(entangled: string): `fme_type' has value `fme_collection'
entangled to [oracle_type]
Coordinate System: `LL-GDA94'
Geometry Type: IFMEAggregate
Front Appearance Reference: `<inherited_or_default_appearance>'
Back Appearance Reference: `<inherited_or_default_appearance>'
Number of Geometries: 2
Geometry Number: 0
Geometry Type: IFMEPolygon
Boundary:
Geometry Type: IFMELine
Number of Coordinates: 10 -- Coordinate Dimension: 2
(145.35239352,-38.04556378)(145.35231797,-38.0457355099999)(145.35380739,-38.04632924)(145.354714,-38.04414865)(145.35458455,-38.04411304)
(145.3532424,-38.04374379)(145.35318438,-38.0437659899999)(145.35252463,-38.0452657599999)(145.35246905,-38.0453921)(145.35239352,-38.04556378)
Geometry Number: 1
Geometry Type: IFMENull
SpatialRelator_<Rejected>(TeeFactory): SpatialRelator_<Rejected>: Termination Message: 'SpatialRelator output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
SpatialRelator(SpatialRelationshipFactory): A fatal error has occurred. Check the logfile above for details
FeatureReader is creating an aggregate from features with different coordinate systems: '' from the Initiator feature and 'LL-GDA94' from the read feature. The aggregate will be tagged with the coordinate system from the read feature. The Initiator geometry is not reprojected
  • January 11, 2018
Hi @jasonjungict, the rejection reason is that the input geometries could be MultiArea or Aggregate, whereas you have set "Support All Predicates" to the "Support Mode" parameter in the SpatialRelater. The SpatialRelater with this mode will reject Multi and Aggregate geometries.
"Support Mode
Support Aggregates: (default) Both multi and aggregate geometries will be supported. However, the only available predicates will be Contains, Equals, Intersects, Touches, and Within. The Overlaps predicate and the Crosses predicate will not be supported. 9-character masks representing Dimensionally Extended 9 Intersection Matrices will also not be supported.
Support All Predicates: All the predicates described in the Spatial Relations Defined page will be supported, except Disjoint. However, aggregate and multi geometries will not be supported." -- SpatialRelator Help
Is there any problem if you change the mode to "Support Aggregates" (Test to Spatial Predicate: Requestor Intersects Supplier)?
  • January 11, 2018
"Support Mode
I noticed that your aggregate geometry consists of a Polygon and a Null.
Geometry Number0
Geometry Number1
If all the input geometries have the same structure, you can use the Deaggregator and the GeometryFilter to transform the aggregate to a non-aggregate Area by removing the Null part. Then, the "Support All Predicates" mode would be available.
  • January 11, 2018
"Support Mode
I found the reason why such a strange aggregate (polygon + null) occurred. Because you have set "Aggregate Initiator and Result Geometry" to the Combine Geometry parameter in the SQLExecutor. Is there any specific reason for using the option?
If you changed the parameter setting to "Result Geometry Only", everything would be all right without any additional transformer, I think.
Hi Takashi,
I appreciate your replying with the right approach including getting rid of wrong settings.
By the way, the result of the new Workspace which I attached gives the different result.
As I explained, I want to find Planning Zone which is overlapping Parcel. But the result includes
Planning Zone which is overlapping boundary between two as attached.
Result for Parcel(SPI) A\\PS439634
  • Finding Planning Zone : 598611 (It is not expected)
  • Finding Planning Zone : 586792 (It is expected)
  • Finding Planning Zone : 586224 (It is not expected)
Result for Parcel(SPI) : 140A\\PP2159
  • Finding Planning Zone : 622730 (It is not expected)
  • Finding Planning Zone : 622729 (It is expected)
I will much appreciate if I can have any idea to have the right result.
Thanks,
Jason Jung
  • January 15, 2018
According to the "de9im" of the resulting requestor features shown in your screenshot, FME has determined that the requestors overlap with the "unexpected" suppliers. I guess there are slight overlaps which definitely exist but are invisible.
See here to learn more about "de9im": Spatial Relations Defined
If my guess was correct, there are two approaches which are worth to try.Use the AnchoredSnapper (Snapping Type: Segment Snapping) to exactly match the boundary of requestors with the boundary of adjacent suppliers.or,If a requestor should be contained by a supplier entirely, use the Bufferer to slightly shrink the requestors by a negative buffer amount, then test "Requestor is Within Supplier".
