File GDB Reader vs Geodatabase Bug - Null Geometry
dfresh
I think this could be either a bug, or an issue with my understanding.
image below, why would the exact same feature class, put through the exact same geometry validator yield different results between readers
  • Top scenario in image is with Geodatabase File Reader
  • Bottom in image, is with File GDB reader
Best answer by takashi
Hi @dfresh, I think it has been caused by a difference between implementations of extrenal libraries - Esri ArcObjects (GEODATABASE_FILE) and File Geodatabase Open API (FILEGDB). Esri ArcGIS has some tolerance internally, so I suspect that the GEODATABASE_FILE reader (Arc Objects) could repair invalid geometries implicitly in some cases.
I'm interested in what happens if you insert the ArcSDEGridSnapper after the FILEGDB reader.
Forum|alt.badge.img+19
  • January 20, 2018
  • January 22, 2018
I agree. Maybe even try a CoordinateRounder after both of the readers and before the GeometryValidators..
tim_wood
Forum|alt.badge.img+8
  • January 25, 2018
What happens if you attach a GeometryFilter to each Reader?
Are they single part or multi-part features? Would de-aggregating help?
Note also that the ordering of the issues in the GeometryValidator can change the output geometries.
These links may also be useful:
https://knowledge.safe.com/articles/173/what-is-the-arcsdegridsnapper.html
http://edndoc.esri.com/arcsde/9.3/concepts/geometry/shapes/verificationrules.htm
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//006z00000028000000
