Hello...any idea how to remove the word 'None' from blank records present within a html report created with HTMLReportGenerator? Thank you.
HTMLReportGenerator Output with 'None' in Records
Best answer by jdh
There's isn't an option on the HTMLReportGenerator for handling missing attributes, but you can get around this by adding empty attributes to the features missing them.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
