JSON support using JSONTemplater
jorge_rosales
Forum|alt.badge.img+8
I am trying to generate a JSON file that includes elements like this one:
But I have problems with the "positions" property. I can´t reproduce it. I can get and array ([] instead of {}) and each element like "9": [220000, 3230000] with non desired {} at the begining and the end.
I attach the full project () with the target.json that I need.
Thanks in advance.
Best answer by juanchuchow
Try changing the value for the "positions" key in la ISLA subtemplate to this:
"positions": {| fme:process-features("POSITIONS", "id_isla", fme:get-attribute("id")) |}
Notice "|" in wrapping "{|" and "|}". "{| |}" is a merge constructor, used to merge several objects.
I ran your workspace with the "{| |}" change, instead of an array of objects you'll get a single merge object.
Hope this helps.
Juan
geosander
Forum|alt.badge.img+7
  • August 29, 2017
Ah yes... it's a royal pain to insert key-value pairs from features into an object. Arrays/lists are easy though... And if you omit the {} in your POSITIONS sub-template, the JSONTemplater throws an error - I wish it would allow for text in the JSONTemplater window without enclosing {} as long as the whole resulting document proves to be valid JSON!
I have been struggling with this before and ended up creating the objects with a PythonCaller and the JSON library...
juanchuchow
  • August 29, 2017
Hope this helps.
Juan
geosander
  • August 29, 2017
juanchuchow wrote:
Hope this helps.
Juan
Wow, that is a nice trick @juanchuchow1323! Never knew that the | (pipe) thing works like that in the JSONTemplater, so I'm glad I learned something new today! :) Wish I knew about this sooner... would have saved me a lot of work...
@j4 or @TiaAtSafe: please mark Juan's reply as the correct answer, so other people can find this too!
danilo_fme
Forum|alt.badge.img+41
  • August 29, 2017
juanchuchow wrote:
Hope this helps.
Juan
Great @juanchuchow1323
Forum|alt.badge.img+21
  • August 30, 2017
juanchuchow wrote:
Hope this helps.
Juan
@juanchuchow1323, thanks for sharing the tip.
There are only few resources about JSONiq on the Web. I finally found this one.
JSONiq Extension to XQuery 1.0 > 4.2. Object Constructors (Example 4.3. Dynamically building an object)
jorge_rosales
  • August 30, 2017
juanchuchow wrote:
Hope this helps.
Juan
It works perfectly! @juanchuchow1323 thanks a lot for the tip.
