Peak process memory usage
  • September 21, 2017
  • 94 views
Forum|alt.badge.img+49
I'm seeing something weird on my non-Windows FME's in build 17539: the peak process memory usage that's reported at the end of a logfile is 0...
This is on my Mac:
And this is on FME Cloud (Linux)
A Windows machine with the same FME build does show it correctly.
Anybody else notice this?
Best answer by nathanatsafe
Hey @redgeographics, thanks for posting. And good find!
This does seem to be a known issue in MacOS and Linux FME. The problem has been recorded internally as bug 54606 and is targeted for a fix sometime in 2018, so we're working on it!
Until then, bask in the magic of.. anti-memory? ;)
Or did FME suddenly become really good at memory management? ;)
nathanatsafe
Forum|alt.badge.img+7
rylanatsafe
Forum|alt.badge.img+13
You will also notice that the reported amount of available memory is astounding.
