From the attribute above containing newlines, I'm trying to extract each line of coordinates into a list using a StringSearcher with regex: \\n.+°.+°.+\\n
I don't want lines of text to be included in the list that are not coordinates, so the first line starting with "Buoy" would not be captured. It should also be noted that the lines that are not coordinates may contain a '°' symbol, such as "Range line at 186°". Because of this, my methodology consisted of matching any set of characters containing 2 '°' symbols that fall between two newlines.
My example regex seems to close, but it is also capturing the first 2 numbers of the next string. How would I need to format my regex to avoid this?
