Extract roof height and building footprint polygon from 3D data
  • November 18, 2019
  • 164 views
I have a dataset with 3D buildings like this:
The dataset is a gdb-file (geode-multipatch) with aggregate geometries.
I need to extract the roof height for each part of the building (meaning one building gets multiple height values for each part – e.g. the second building from left in the front row in the screenshot should have a different value for its tower). The height should then be a attribute for the below mentioned polygon.
And I also need to extract the footprint as polygon shape for these building parts. How could I achieve this?
sigtill
Forum|alt.badge.img+24
  • November 18, 2019
Hi @oiram Use the BoundsExtractor to find max-min z. Use the SurfaceFootprintReplacer to find the Footprint.
  • November 18, 2019
Thanks for pointing me to these transformers!
  • March 30, 2020
Hello,
can I use the same transformer "BoundsExtractor" to find heights in raster GEOTIFF, which includes floors and buildings as shown in the figure:
