Issues with Run with Feature Caching and Inspector Transformer
Hello guys, I am a new FME Desktop user and I have a Home Edition License. I started the basic training and during the excercises I came across some issues with "Run with Feature Caching" and the "Inspector" transformer. Basically when I turn on the "Run with Feature Caching" or when I use the "Inspector" the translation fail and I get this errors:
In addition, the feature "Redirect to FME Data Inspector" does nor work and the Data Inspector itself never opens.
Could you please help me?
Many thanks
  • April 19, 2018
Using FME Desktop 2018.0.0.1
erik_jan
Forum|alt.badge.img+17
  • April 19, 2018
All the mentioned features are using the TEMP system setting for storing temporary files.
Almost looks like this setting is pointing to a non existing location (or at least one that FME can not use).
fmelizard
Forum|alt.badge.img+18
  • April 19, 2018
  • April 20, 2018
I actually had a temp folder to which FME was pointing, so I tried to create another one named FME_TEMP in another location and now it works. Thank you very much guys :-)
