I am trying to utilize a file share within a workbench and establish a network based resource connection on FME Server through the web ui but receiving errors that we have been unable to diagnose. In both uses, the error states "Folder not found" and the location is being referenced by unc path (e.g. \\\\server-name\\folder). The folder in question contains a space, so I have attempted using single quotes and url encoding the unc path with no success. We currently use other file shares within FME Server, and have granted the computers credential (e.g. mango$) read/write access to those resources with success. From the system that runs FME Server, I can verify that other users can access the file share in question, so there doesn't appear to be a firewall issue or other connection related issue. Any help would be appreciated in resolving this issue.
We are currently on FME Server 2017.0.0.1
