Extrude surface
Hi all,
Is anyone familiar with (reverse) extruding of a surface?
I want to extrude it down to 0 for the entire surface to get a firm base.
Doesnt seems to work with the extruder-transformer
Thanks
gio
Forum|alt.badge.img+15
  • August 5, 2014
How about exploding it (if it is a solid) and aquiring the bottomsurface (by z =0)?
If its not a solid, just extrude a bit, then explode then aqcuire bottom.
Forum|alt.badge.img+19
  • August 5, 2014
You can use "Vector" mode as Extrusion Input By, and set an appropriate negative value to Extrusion Vetor Z.
Takashi
  • August 5, 2014
Thanks, but cant find any way to extrude a TIN surface. Works fine with triangles etc but not surface
Henrik
  • August 5, 2014
Combination of the GeometryCoercer (Geometry Type: fme_comoposite_surface) and the Deaggregator (Split Composites: Yes) can be used to decompose a TIN surface into individual triangle surfaces. And then, you can apply the Extruder.
  • August 6, 2014
Thanks Takashi,
It works to extrude them when they are splitted but still cant find a way to extrude them down to 0. The extruder only allows me to extrude to a value and since its triangles with 3 different z:s it still doesnt give me a fim base.
Henrik
  • August 6, 2014
hmm, I was able to extrude the surfaces to negative direction in both these cases.
Extrusion Input By: Height
Extrusion Height: <negative value>
or
Extrusion Input By: Vector
Extrusion Vector Z: <negative value>
FME 2014 SP2 build 14339
