crosstab/pivot transforming for database
I have a table with the following:
Identifikation AuftragsNr FeldValue a1 20160770 450 a2 20160770 EUR/m² a3 20160770 Kita a4 20160770 25.11.2016 b1 20160770 250 b2 20160770 EUR/m² b3 20160770 Kirche b4 20160770 25.11.2016 c1 20160770 350 c2 20160770 EUR/m² c3 20160770 Keller c4 20160770 29.11.2016
I am trying to create a new table with the following:
AuftragsNr
a1 a2 a3 a4 b1 b2 b3 b4 c1 c2 c3 c4 20160770 450 EUR/m² Kita 42699 250 EUR/m² Kirche 42699 350 EUR/m² Keller 42703
I am currently using FME Esri Edition Desktop 2015.1.2.1
I hope that someone can help me.
Thanks in advance!
Mat
  • December 15, 2016
Hi @schlauma, a possible way is:
  1. BulkAttributeRenamer: Rename 'FeldValue' with the value of 'Identifikation' (a1, a2, ...)
  2. Aggregator: Aggregate the features grouping by the 'AuftragsNr'.
  3. AttributeExposer: Expose the new attribute names (a1, a2, ...).
  4. AttributeRemover: Remove 'Identifikation' and 'FeldValue', if necessary.
The workflow and the BulkAttributeRenamer parameters setting look like this.
  • December 15, 2016
Thank you takashi,
it works perfect.
greetings from Germany
regards Mat
