Hello,
I have an external command line tool consisting of a single executable file that I'd like to run via a workbench on FME Server. Are there any recommendations on how I'd go about uploading the tool onto the FME Server environment and setting the environment path variable?
I'll likely need to involve the platform administrator, but I'd like to know what the best approach is first so that we have a clear idea on how best to set it up.
Thanks.
