intersected lines with blocks and change output lines with different colour
  • February 3, 2020
  • 5 views
soly
Forum|alt.badge.img+3
i want to ask about my issue:
in my map,i have many lines and many blocks and i want to say ,if the line has red colour touched the block so any line get out of this block will take deifferent colour and get new id
First ,what i understood i have to use lineonAreaOverlayer transformer to find which line intersected with blocks
but how can i put a condition if any red line that include base id touched the block so any lines get out of this block will get different colours and each line will have new Id
Thanks
sigtill
Forum|alt.badge.img+24
  • February 3, 2020
Hi @soly Do you have an example datast with 4-5 blocks and corresponding lines?
