Character Encoding of resolved domain values using ArcSDE Geodatabase reader
I was wondering, did anybody come across the invalid characters being shown for the domain values in the output while reading from an esri featureclass when the parameter is set to resolve domains.
In my case, the domain description are having Arabic characters, for which my output is showing '????????'. Are there any settings or parameters in the workbench to set the character encoding settings or anyone come across such an issue and had a solution or work around.
Regards
Nandakumar
  • January 23, 2017
Hi @n1
unfortunately this is a known issue. We have PR # 17258 filed in our system, I added a comment regarding your question to increase the PR priority.
I wonder if it is possible to find a workaround for this problem (e.g. reading domain description values separately and then merging them with the features). Please feel free to submit a support case through http://www.safe.com/support/ - our Tech Experts team will be glad to try to help.
fmelizard
Forum|alt.badge.img+18
  • February 10, 2018
Hi @n1 PR # 17258 is now fixed in builds 18265+ at www.safe.com/beta
