We've just recently begun to adopt the MBTiles format for offline map viewing.
What I expect is a TMS setup, with every tile level at its optimal resolution, i.e. w/o undue pixellation.
I've made some test, but it seems that the MBTiler writer only accepts a raster image, i.e. an already fixed resolution. This results in a pixellated lowest (or highest?) level.
How do I create an MBTiles dataset from my vector map data, with full resolution on all levels ?
The WebMapTiler also expects raster input, so that's not immidiatedly an option.
Any insights are appriciated. Using 2018.1.
Cheers
