Ora12154 TNS:could not resolve the connect identifier specified
  • July 20, 2016
  • 87 views
pushpa
Forum|alt.badge.img+9
Hi there,
I have 4 FME workbench files on Win2008 server and execute those workbench files using a batfile.
I can run the batfile without getting any errors but USER2 cannot run this bat file.
User2 get following error.
## Start translation ##
FME 2015.1.3.0 (20151105 - Build 15570 - WIN32)
FME Desktop Oracle Edition (floating)
Permanent License.
Machine host name is: WBV-GCS-P0011
Operating System: Microsoft Windows Server 2008 R2 Server 4.0, Enterprise Editio
n 64-bit Service Pack 1 (Build 7601)
Copyright (c) 1994 - 2015, Safe Software Inc.
Safe Software Inc.
Error connecting to Oracle database: message was `ORA-12154: TNS:could not resol
ve the connect identifier specified'. (serverType=`ORACLE8i', serverName=`vmesde
v<at>gisap.world', userName=`', password=`***', dbname=`')
Program Terminating
Translation FAILED.
## End translation Closure_GB_NI ##
User2 is Administrator to this sever and can connect to Oracle Database using sqlplus. But User2 cannot connect to Oracle Databse using FME
Any help would be appreciated
Thanks
pushpa
  • July 20, 2016
hi there,
Just to let you know that I have managed to sort out this issue.
User2 didn’t have Database connection saved under Database connections on FME options. Once User2 saved the Oracle connection then able to run the bat file without any errors.
thanks
