set writer destination at runtime
Hi all,
As a newbie, I'm having a hard time getting my head around a possible simple task. I need to write features to different destination folders created at runtime.
My workspace basically generates per feature an unique id (uuid), stores it as attribute and creates in a published directory a subfolder with that name. The next step would be to write each feature in its newly created subfolder as a SHAPE. I couldn't figure out a way to define the writer's destination at runtime. I already unsuccessfully tried a fanout
I expect this task to be rather a standard situation but, due to my lack of experience, didn't find a solution. Your help is greatly appreciated!
Cheers,
Alain
Best answer by david_r
sounds like a case for the dataset fanout (http://fmepedia.safe.com/articles/How_To/Fanout#heading_toc_j_2).
David
  • January 5, 2015
David
  • January 5, 2015
Thanks David, it's working now like a charm! I wasn't using the fanout properly (feature type instead of dataset fanout) and did only get filenames as concatenated but no subfolders. Thanks for the quick help!
