Yesterday I used the FME clipper transformer to curve out unwanted portions in a polygon feature class from another polygon feature class. Both feature classes are in two separate Esri file geodatabases. It is a very simple geoprocessing operation, but it runs very very slow, measured in hours, some even became hung. Tested this in several feature class datasets, the same behavior - terribly slow. On the other hand, using the Erase geoprocessing tool in ArcGIS desktop, it finishes in 2 - 5 minutes for all the tested datasets. The results between FME and Esri Erase tool are exactly the same. So wondering why the FME clipper is so slow. I have been successfully promoting FME in my company in the last few months, but this came as a big slap on my face. I am at FME 2019.2.
