Any suggestions on how to convert contents of attribute into bullet list in Markdown?
friesewoudloper
My dataset has an attribute that contains a list of item descriptions and hyperlinks:
Item 1|http://www.item1.com^Item 2|http://www.item2.com^Item 3|http://www.item3.com
I'd like to change the contents of the attribute into a bullet list in Markdown:
[Item 1](http://www.item1.com[Item 2](http://www.item2.com)
[Item 3](http://www.item3.com)
What would be the best way to do this? The list in the attribute can contain zero, one or n items.
  • October 25, 2018
On solution could be to use an AttributeSplitter on "^" followed by a ListExploder and a StringReplacer where you look for the following regex:
and replace it with:
[\1](\2)
friesewoudloper
[\1](\2)
Thank you very much!
