Mysterious error in PythonCaller, undeclared variable "not defined"
lifalin2016
Forum|alt.badge.img+29
Hi.
I've just encountered a mysterious error in a PythonCaller in a workspace :
2018-11-07 20:17:02| 811.7| 3.9|WARN |Python Exception <NameError>: global name 'feature' is not defined
2018-11-07 20:17:02| 811.7| 0.0|WARN |Traceback (most recent call last):
File "<string>", line 16, in input
NameError: global name 'feature' is not defined
2018-11-07 20:17:02| 811.7| 0.0|ERROR |Error encountered while calling method `input'
2018-11-07 20:17:36| 843.3| 31.5|FATAL |Delete_temp_file(PythonFactory): PythonFactory failed to process feature
The problem is, that my code in the "Delete_temp_file" PythonCaller transformer doesn't have any variable named "feature" in it (I renamed it from the template's "feature" to "ft") :
import fme
import fmeobjects
import os
class FeatureProcessor(object):
def __init__(self):
pass
def input(self,ft):
try:
pass
pthnam = ft.getAttribute('tile_temppath')
os.remove(pthnam)
except:
pass
self.pyoutput(ft)
def close(self):
pass
Is the error resulting variable "feature" something that's hardcoded behind the scene ?
Cheers
Best answer by lifalin2016
Apparently the cause of the error is still as mysterious as when I wrote the question. As it's fairly easy to avoid (don't rename "feature" in input()), I'm closing the question.
Forum|alt.badge.img+35
  • November 8, 2018
feature is not a variable in the template code, it should not be renamed
  • November 8, 2018
Also, you can safely delete all the "pass" lines inside the input()-method. The'yre not the source of the error, but the don't do anything either.
  • November 8, 2018
Actually, the code works for me both in FME 2018.1 and 2017.1 even when the "feature" parameter has been renamed in the input()-method.
  • November 8, 2018
Are you sure you've posted the complete code? I'm not able to reproduce the problem on my side.
  • November 8, 2018
ah, so it does
  • November 8, 2018
Another thing, perhaps a bit unrelated: If you simply need a temporary file during your translation, I really recommend using the TempPathnameCreator rather than implementing something in Python.
Upsides of the transformer are:
  • Works seamlessly on Windows, Linux, OSX
  • Respects system settings that define temporary file locations (roaming profiles, etc)
  • No code to write and maintain
And best of all: FME will automatically deletes the temporary directories/files created using this transformer, so you don't have to. It even works if FME crashes.
lifalin2016
  • November 8, 2018
The PythonCaller doesn't create a temp file, it deletes it.
  • November 8, 2018
Indeed, but I'm assuming that the file is created somewhere first :-)
But yeah, perhaps it doesn't apply to your case...
lifalin2016
  • November 8, 2018
No, most of the "pass" lines are actually needed, as Python needs at least one line of code in any context.
I can see that the web UI has deleted all the relevant indention. How come the possibility to add un-reformatted code in this web UI has been removed ?
lifalin2016
  • November 8, 2018
But why does FME then issue the error message then, naming the offending "feature" variable ?
  • November 8, 2018
There was an update to the forum update earlier this week and Safe is still trying to iron out some wrinkles.
Can you post the code as an attached .txt file? That should hopefully work.
  • November 8, 2018
Difficult to tell since I cannot reproduce the issue. Is it possible to post a minimal sample workspace that reproduces the problem?
mark2atsafe
Forum|alt.badge.img+44
  • November 8, 2018
Can you try adding a feature into the close method? So the last few lines would be:
def close(self):
feature = fmeobjects.FMEFeature()
pass
From another case I've seen, I have a feeling this might help.
mark2atsafe
  • November 8, 2018
def close(self):
pass
Sorry, that
character isn't required. We're having a few quirks with the latest knowledgebase update.
lifalin2016
  • November 9, 2018
As a curiosity, and renamed "ft" back to "feature" in my code, and now it doesn't err !?!
Besides the error reference (line 16) was "def close" in which I only have a "pass" statement, prompting me to an assumption error in some hidden "code-behind".
lifalin2016
  • November 9, 2018
It's created by the output of a WMS call written by AttributeFileWriter.
lifalin2016
  • November 9, 2018
FME_PythonCaller_error.txt
lifalin2016
  • November 9, 2018
I renamed it back to its original, in which "feature" is replaced by "ft" in def input()
lifalin2016
  • November 13, 2018
